MLX to CpLX Conversion tool
Oceansoul
Apr 2010
England
307
I am trying to convert a program from MLX to CpLX using the conversion tool. I am getting an error unable to find *.txt file. Would anyone be able to run the attached *.rss file through there conversion too and post the outcome *.acd? I will worry about tidying the code etc The CpLX controller will be a 1769-L24ER-QBFC1B. Thanks if anyone can help.
It was short enough to convert by hand....
Everything retained, all the SLC style addresses have been changed to array tags, arrays same size as old data-tables...
e.g.
N9:2 = N9[2]
T4:3.DN = T4[3].DN
Converted to Studio5000 V21 - if you don't have V21 to open it, let me know what you have. (You'll need at least V16, because I've used the SCP Add-On Instruction Sample)
Check the scaling parameters for the RAW/Proportional data from the on-board analog inputs.
from the manual - "Raw/Proportional - The value presented is proportional to the selected input and scaled into the maximum data range allowed by the bit resolution of the A/D converter." - it is a 16-bit signed value, so I'm assuming 4mA = 0, and 20mA = +32,767
Any problems - let me know...
Wow. Thanks for that. I was expecting to have to convert it myself. I had already done this once, as currently there is a Mitsubishi FX PLC, which I am replacing. Originally I was told to use a micrologix then management changed their minds and I was told to use a compactlogix. I am going to modify the code to make it more efficient.
Once again thanks for your help.
Why waste time modifying it ? Admittedly it's not "Logix5000 tuned", but it's only a small program and making it prettier and faster will serve little purpose. I thought about bringing it up to date while converting it, but had second thoughts.
At least the way it is, there's more of a chance it being "familiar" to anyone who knew the Mitsi application. And of course you know it works as it is.
Just my 2c :)
Addendum : reading between the lines, I see .....there never was a MiroLogix.... Perhaps the Logix5000 application that uses 500-style data-table arrays isn't the best format.... I'll leave it up to you how you proceed....
Hey Guys, I am struggling to read data from a "JUMO" make controller using modbus RTU with MLX1400. The communication between the devices has...
18
5,081
Is it possible to create MSG in SLC to read data from a mircologix 1000 via serial DF1? I have Micrologix 1000 and SLC5/04, the serial port on...
1,789
HELLO BOYS, I HAVE AN INTERROGANT, HOW CAN I MIGRATE A PROGRAM FROM A PLC MICROLOGIX 1500 TO A PLC 1400:beerchug:
1,629
Newbie question here, I have been trying to setup a Ethernet/IP network consisting of 3 AB Micrologix 1400 plc's, one Idec HG4G-CJT22MF-B OI, and...
3,332
I'm converting a Micrologix 1400 (1766-L32BXB) PLC program with a PanelView Plus 6 (2711P-K6M5D8) HMI to a Compactlogix (1769-L30ER) PLC with a...
3,579
