MM440 Micromaster Frequency Converter
userxyz
May 2002
any
2,768
A drive running a motor @ 50Hz takes 13Amps
How much will it take before the drive ?
More or less ?
Hi Combo.
I assume you mean same voltage and frequency on line side and drive side.
If it was less current, then you would have invented a means to generate free electrical power. Unfortunately I dont think this is the case.
In principle it should be the same current, but as there are some losses in the drive itself, you must expect a slightly higher current on the line side.
tnx
More current on the motorside when the frequency is lower then 50Hz is what we have seen, and that's logical.
And indeed, when running @ nominal speed we have same current on both sides and little more line current.
Thanks for your reply
Witam! I have got a problem. I must replace Micromastr Vector to MM440. In Micromaster Vector are set parameters but I can’t find all its...
4,362
I have some questions about F0070 (profibusfault). These faults happen now and then... I know that u may not send zero to the controlword, or...
10,256
How would u start, invert direction and reset fault, do u use the Drive ES Blocks for simple projects, or do u just write something yourself ...
4,334
Hey, I have a 2,2kW motor that runs @ 50Hz with an MM440 frequency drive. The drive is connected on profibus. Because of the load, the motor...
6,623
I have 2 MM440's and I connected DC+ to DC+ and DC- to DC-. I changed parameter P1240 to 1 on both drives. I used fuses 15Amps. The drives are...
3,943
