Starting a Micromaster MM440 on profibus
userxyz
May 2002
any
2,768
How would u start, invert direction and reset fault, do u use the Drive ES Blocks for simple projects, or do u just write something yourself ?
Is it a good way to transfer 47F to start, 47E to stop, C4F to reverse and 4FE to reset ?
I think maybe some others can tell you about sending special codes to the drive to control it.
I gave up on that approach. In stead I found an example at Siemens support with a complete project including HMI projects:
http://www.plctalk.net/qanda/showthread.php?t=18348
What makes this really really good is that you get a very comprehensive diagnostics with meaningful onscreen explanations. This is near impossible to make by one self.
Unfortunately the last I looked all this was in german language only.
hi
After discussion in an other topic I wrote this:
PZD is an UDT that contains the status and control
LAR1 P##PZD
L #STAT_WORD
T LW [AR1,P#3.0]
SET
= #PZD.Off_2
= #PZD.Off_3
= #PZD.Enable_Oper
= #PZD.Oper_Condition
= #PZD.Enable_RFG
= #PZD.Enable_Setp
= #PZD.SETP_Valid
A #FW_RUN
AN #RV_RUN
JCN RV
= #PZD.On_Off_1
[size=+0]RV: [/size][size=+0]A #RV_RUN
AN #FW_RUN
JCN RST
= #PZD.On_Off_1
= #PZD.SETP_Inv
[/size]RST: A #FLT
A #RST
= #PZD.Ack
LAR1 P##PZD
L LW [AR1,P#0.0]
T #CTRL_W
L #SETP_Hz
L 5.529600e+002
*R
RND
T #SETP_Int
opnion
Look, what I want to know is..
If u just want tu Run a motor with an MM440, and u only use PZD and no PKW...
Should u use DriveES blocks If u have Drive ES ?
Or do u transfer start/stop and speed just like:
L w#16#47F
T PQW 256 // control word
L w#16#4000
T PQW 258 // Setpoint
Or do u write every bit in an instance or something ?
Hey
indeed, but someone of our team does not agree and just wants a lot of unnecessary work with these blocks. He even programs it in Lad, what makes it even more, more work, more code.
If u use more then 2 words IN and 2 words OUT, then maybe you can use these blocks, but not for a simple application where u only need RUN Forward, Reverse, Fault Reset, en that's it...
What do u think ?
What's the advantage of these Drive ES blocks ?
When I did my first Profbus MM4XX project earlier last year I used the blocks from The Siemens Support site as you mentioned in an earlier post. I had a few niggles with these blocks so I spoke to Siemens A & D Support here in the UK. They advised me to use the Load and Transfer method and indeed sent me a small program demonstrating the routines.
Regards
pouch
Opinion on how to control
I first wrote an UDT with a controlword and a statusword.
Then I did this in an FC:
Network 1:
LAR1 P##PZD // Pointing to UDT
L #STAT_WORD // Statusword from drive PIW256
T LW [AR1,P#2.0] // transfer to statusword(UDT)
Netwerk 2:
L 0 // Load zero to reset all bits
T LW [AR1,P#0.0] // transfer to controlword(UDT)
SET
= #PZD.Off_2 // these bits must be high
= #PZD.Off_3 // These bits make 47E
= #PZD.Enable_Oper
= #PZD.Enable_RFG
= #PZD.Enable_Setp
= #PZD.SETP_Valid
Netwerk 3:
A #FW_RUN // Start Forward (this makes 47F)
AN #RV_RUN
JCN RV
= #PZD.On_Off_1
Network 4:
RV: A #RV_RUN // Reverse (makes C7F)
AN #FW_RUN
JCN RST
= #PZD.On_Off_1
= #PZD.SETP_Inv // invert bit
Network 5:
RST: A #PZD.Fault // fault from the statusword
= #FLT
A #RST
= #PZD.Ack // resetbit
Network 6:
LAR1 P##PZD
L LW [AR1,P#0.0] // At last load the controlword
T #CTRL_W // from the UDT and transfer to PQW
In network 2 I used this:
L 0
T LW [AR1,P#0.0]
When I do not do this, then bits that must be zero sometimes do things I don't want, maybe because they are temps ??
Hi All I have the SIEMINS micromaster 440 not starting good several times then start after 1 to 2 hours . so I took the AOP kit and opend it >>...
4,453
Hi, I am attempting to turn on an output for one second, every thirty seconds, but am having some trouble. I have a XIC with S:1/15 (first pass)...
595
Rather new to structured text. I'm trying to edit a machine so that it will reinitialize with some push buttons held in for 10 seconds. Pushing...
2,752
Hi Guys, I'm using an ABL33ER with Panelview 600. I have datalogging running on the HMI using the view studio datalog model on startup of the...
1,145
Hello guys, I have windows 10 on virtualbox guests and not on the host. On a windows 10 guest I have TIA Selection tool V2022.06. When I...
1,515
