Modbus Cable Specifications
jose7771
Jan 2005
42
HELLO FRIENDS,
I AM TRYING TO PROCURE A CABLE WHICH WILL BE INTERFACED
TO MY PLC WITH A DCS ( HONEYWELL), THE PLC BEING USED IS GE FANUC (IC6958 CPU 310) THROUGH RS 485 PORT ,15 PIN ,BOTH DCS AND PLC WILL BE LOCATED IN THE SAME CONTROL ROOM ,DISTANCE BETWEEN THEM IS HARDLY 10m
HOWEVER I AM NOT ABLE TO FIND OUT WHAT SORT OF CABLE,(SPECIFICATIONS) TO PROCURE
REGARDS
JOSE
1) You need to dig through the Honeywell documentation to discover
- which serial port will be used
- whether it is RS-232 or RS-485
- what it's pin out wiring is.
- if it is RS-485 whether it is 2 wire half duplex or 4 wire full duplex
You also have to determine whether the Fanuc RS-485 port is 2 wire, half duplex or 4 wire full duplex.
Once you have that sort of information, then it's possible to figure out what cabling/wiring is necessary.
2) RS-232/485 is a hardware standard, and says nothing about the protocol or control language used to communicate data.
Is the Honeywell a Modbus master and the Fanuc a Modbus slave, or vice versa? Or are you using some other protocol?
Dan
Gents - hope somebody can help out, I've been tasked with fixing an OLD SCADA system. I've got an S7-226 PLC thats configured for Modbus comms via...
1,463
I have a task to connect devices to a Control Logix PLC. First time working Modbus and HART from scratch. Like to know if I can use the same...
1,467
For an upcoming project, the GC has chosen this wire: https://www.mayerelectric.com/itemDetailFilterPH.action?codeId=1189529 There will be three...
2,046
what is the maximum length of cable can modbus rtu go? do you have any curve showing cable distance versus baudrate?
3,667
I want to connect a m340 2020 cpu to two devices in 300m long. One with ethernet port and one with modbus port of m340. I want to know witch cable...
3,267
