Siemens S7-200 to SCADA cable pinout (Modbus)
rtgibson
May 2012
Barnsley
44
Gents - hope somebody can help out, I've been tasked with fixing an OLD SCADA system. I've got an S7-226 PLC thats configured for Modbus comms via PORT 0 (on the PLC). I can see that in the PLC and the baud rate setup etc.
On the other end at the PC I have a USB to 422/485 converter - I can't for the life of me find a cable diagram on the internet, does anybody have a pinout diagram to connect from 422/485 to the 9 pin PLC connector ?
On the 422/485 converter there are 4 pins (well 5 - one for ground) TD-, TD+, RD-, RD+.
Thanks in advance.
Russ
Here is an example:
Connect TD+ & RD+ to pin 3 on the S7-200 CPU port
Connect TD- & RD- to pin 8 on the S7-200 port
Connect SG (or GND) to pin 5 on the S7-200 port
hi,i m new to the world of PLCS. i m working on a graduate project on S7-200 with cpu 212. i m to automate a plant and give its graphic...
5,779
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
255
commentaire communiqué siemens s7-1200 avec vfd delta ? (cablage et sur tia portal )
131
Hi, I have a 1214 on ip 192.168.0.100. This is connected to other modules through a switch on same network. I need to connect this to a company...
180
Hi Experts, I would like to make firmware upgrade from v3.0 to v4.5 (S7-1200 CPU 1215C). Can I do it from v3.0 to v4.5? Do I need to take some...
289
