Modbus communication with MV panel
parvezl
Aug 2006
mumbai
We have two panels, one is MV(6.6kV) and the other is LV(415V) having the PLC. The panels are both in different rooms.
My Schneider PLC from LV panel needs to communicate with the MV (6.6kV) panel which has breakers and power meters on Modbus.
I have the following queries as to what precaution should i take in routing and using the communciation cables.
1. Is it ok if I use shielded twisted pair cables for communication.
2. What should be the minimum distance between the power cables and the Modbus communication cables.
3. I will be using a RS485 port Isolator on the PLC. Is is enough.
Thanks in advance.
hello i have Honeywell ST-71 REPEATER PANEL. can anyone tell me how to connect this ST-71 to the system 57 through Modbus communication. i have...
4,673
Apologies for not being the best IDEC programmer. I recently was doing some inspections on a site that had 3 FC6A IDEC processors. The issue is...
88
Hi all I need help on this As in my project used Schneider TM241 controller. Now I want to communicate Elite energy meter with controller by...
170
Hello, I need to access the bits from the fire system control panel through RS-485. So, I used Read Var block to read from the panel...
198
Hi, i cant establish communication between fatek plc with an energy meter, both capable for modbus tcp, i did with modscan but fatek plc does not...
152
