MODBUS COMMUNICATION with RS-485
Actually I have a master k 120s plc and a yaskawa v1000 vbd. and i have no sound knowledge about rs485 communication. so, please help me.
RS-485 is an electrical specification defining the characteristics of the signal line-drivers and receivers in a differential-balanced, multi-node system, no communications protocol is defined.
Modbus is the communication protocol that Garry suggested.
I know nothing of Fatek. I assume Garry does know - or took the time to investigate the documentation of your devices - and that is why he suggested ModbusRTU.I assume that Garry has determined that ALL of your proposed devices support ModbusRTU.
The first sentence in the overview that Garry linked says:
Modbus RTU is an open, serial (RS-232 or RS-485) protocol derived from the Master/Slave architecture
Check your device specifications. If they all support ModbusRTU, carry on!
If not, come back and let us know.
If you get bogged down in the idiosyncrasies of Modbus, come back.
Hello, I need to access the bits from the fire system control panel through RS-485. So, I used Read Var block to read from the panel...
204
I been tasked with setting up communication between a heating cooling unit manufactured by Advantage Engineering and a Microloagix 1400 plc. The...
2,524
Has anyone on here ever connected one of the Dinosaur...I mean Dynapar MAX units (MAX Position, MAX Count, etc.) to a PLC or HMI? I tried...
1,344
I am trying to setup the master and slave for my ML1400 PLC using 2 core ( Tx-1 & Rx-1) RS 485 modbus communication. I received the data as my...
1,778
Hi friends, this is my first post in this forum. I am Implementing an application that works like this: I want use the RS-485 interface of...
4,725
