Modbus Communication
plcnovel
Feb 2006
LHR
215
Hi
I am a novice in plc world. I would like to communicate over the modbus with AB (Compact Logic, MicroLogic) PLCs with the modbus slave devices. I know Compact Logic,and MicroLogic dont suppport modbus communication unless we use a prosoft module with them. My question is, is there a way we can program in the ladder logic to make Compact Logic or MicroLogic work over modbus without a prosoft hardware. if such a way exist, is there any example code i can play with and try to learn. Any help and suggestions will be appreciated. Thanks in advance.
PLC Novel
ML1500 LRP series C processor - CH. 1 Modbus RTU Master or Slave
ML1500 LRP series B procuessor - CH. 1 Modbus RTU Slave
ML1200R (dual comm ports) series C processor - CH. 0 master or slave
ML1200 series A/B processor - CH. 0 Slave only
CompactLogix - must use Prosoft module
Modus communication
Hi
Thanks for your replys. So it means there is no software way of implementing a Modbus protocol in Compactlogic without using a Prosoft module.
Hi folks, I have a Controllogix in communication with a zigbee coordinator using Logix AIO for modbus tcp. This zigbee coordinator have 3 slaves...
99
Apologies for not being the best IDEC programmer. I recently was doing some inspections on a site that had 3 FC6A IDEC processors. The issue is...
107
Hi all I need help on this As in my project used Schneider TM241 controller. Now I want to communicate Elite energy meter with controller by...
187
Hello, I need to access the bits from the fire system control panel through RS-485. So, I used Read Var block to read from the panel...
206
Hi, i cant establish communication between fatek plc with an energy meter, both capable for modbus tcp, i did with modscan but fatek plc does not...
163
