Modbus driver for Kingfisher RTU
moistcat
Jun 2020
Melbourne
54
Does anyone know where I would be able to find the modbus driver for Kingfisher Series 2? (CP-11 CPU).
Toolbox32 is asking for a *.d32 file.
EXISTING FUNCTION - talks Kingfish protocol to Citect SCADA
NEW FUNCTION - Also talks to redlion DSP via modbus on the same physical port.
I actually reached out to Ovarro support and they got back to me super quiet quickly!
They added me to a good confluence site with documentation, drivers, tech notes etc.
PLC: AutomationDirect DL06 Modbus driver: Wonderware InTouch DASMBTCP Goal: read the C100 discrete value from the DL06. I have successfully...
3,841
Scadapak Com Port 3 Rs232 Pin 5 RXD Pin 6 TXD Pin 4 GND On the computer Com Port 1 9 pin IGS Driver can I just use pin 2 , 3 and 5
2,602
trying to create some tags with the modbus drivers in iFix. Normal I would do Channel1.Device1.(tag address) I figured for modbus that would be...
2,934
I am trying to connect a GOT1000 HMI to a Wago 750-881 PLC using the TCP MODBUS driver but can't read the registers I'm using 20 registers from...
4,150
I have to connect more than 50 no of modbus TCP/IP IO devices to Citect SCADA. I will be connecting them as individual ports. Can I give different...
1,910
