Modbus for SLC5/03
svn
Jul 2004
74
In one application, the user wants to connect their DCS with Modbus RTU on RS485 to SLC 5/03. I think SLC5/03 natively supports only DF1 or DH485. What will be the cheaper and more reliable solution in this case - using a DH485/Modbus gateway or using the Prosoft MVI46-MCM Module? or are there any other options?
SVN
ProSoft’s 3150-MCM module, able to directly connect Allen-Bradley’s SLC for modbus communication will be best option
Thanks rPraveenkum,
I downloaded the 3100 3150 User Manual also. I shall go through the manual but mean time can you just tell me the major differences between this module and MVI46-MCM?
SVN
Thanks rPraveenkum for the link
BTW has anybody used DL3500 DH485/Modbus Link? How is it?
SVN
rPraveenkum said:
DL3500 is a DH+ to Modbus protocol Convertor
But in the DL3500-dh-385-modbus Application Note , DataLink have mentioned that it can be used for DH485 also if DH485 Commands in PLC5 format are used with SLCs, Micrologix etc. Does SLC5/03 not support these commands?
SVN
We have a SLC5/05 that's acting as the main MTU for our SCADA system. I need to bring in some data from an AutomationDirect CLICK PLC that...
3,433
After viewing the posts of others and helping whenever I could, it's time for me to post a topic and get some free advice. But then again, you get...
8,509
Hi Everyone, i was hoping for a little help with this module. i have data that needs to be read from a different plc through the Modbus plus...
236
I have a PH meter that I am trying to bring its data into 1756-L81. I have downloaded the Rockwell MODBUS AOI kit, but I am not sure if I need to...
174
Dear All, i am trying to connect Danfoss inverter with s7 200 cpu 226.but microwin shows following error at DATA Ptr.i assigned different VB...
48
