Modbus MSGing Micrologix 1400
bifftannen
Oct 2022
Australia
Good Day!
Would anyone be able to explain what is happening with the COP's and MOV's in this Modbus poll routine? If anything I am confused by the one COP instruction that has brackets "[" and "]" in it's source and destination. I have never seen this before. I suspect the COPs/MOV's are for bit swapping/conversion but because of this one instruction with weird syntax im confused.
Thank you very much
The square brackets indicate indirect addressing used for the source & destination tags. The add instructions on the branches show how the addresses are being calculated.
Look like it’s swapping the high/low words, to correctly convert to floating point values on that last rung.
Thank you! :) Do you have a link to any documentation on indirect addressing for RSLOGIX500?
I am having an issue configuring my messaging and am not understanding the MSG data I am receiving back from the device. Summary of devices...
4,107
Hi Everyone, i was hoping for a little help with this module. i have data that needs to be read from a different plc through the Modbus plus...
227
I have a PH meter that I am trying to bring its data into 1756-L81. I have downloaded the Rockwell MODBUS AOI kit, but I am not sure if I need to...
167
Dear All, i am trying to connect Danfoss inverter with s7 200 cpu 226.but microwin shows following error at DATA Ptr.i assigned different VB...
48
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
222
