Modbus MSGing Micrologix 1400
bifftannen
Oct 2022
Australia
Good Day!
Would anyone be able to explain what is happening with the COP's and MOV's in this Modbus poll routine? If anything I am confused by the one COP instruction that has brackets "[" and "]" in it's source and destination. I have never seen this before. I suspect the COPs/MOV's are for bit swapping/conversion but because of this one instruction with weird syntax im confused.
Thank you very much
The square brackets indicate indirect addressing used for the source & destination tags. The add instructions on the branches show how the addresses are being calculated.
Look like it’s swapping the high/low words, to correctly convert to floating point values on that last rung.
Thank you! :) Do you have a link to any documentation on indirect addressing for RSLOGIX500?
I am having an issue configuring my messaging and am not understanding the MSG data I am receiving back from the device. Summary of devices...
4,133
Hello Everyone, I am using a raC_Opr_NetModbusTCPClient AOI module, as below,. So, I need some assistance to restrict in reducing the poling...
129
I want to communicate my Q series PLC with Factory IO using GX works 2 software, I want to use modbus as server and the ips are as follows plc...
88
Hi folks, I have a Controllogix in communication with a zigbee coordinator using Logix AIO for modbus tcp. This zigbee coordinator have 3 slaves...
360
138
