fbliman
I am trying to connect a micrologix 1500 (1764-LRP) to a Hitachi SJ700-2 inverter.
To connect them i am using ch1 in the PLC (RS-232), a rs-232 to 485 converter, and then i connect it to the 485 port in the inverter.
The PLC is used as master ande the inverter as slave.
I have to read and write some registers. I tried writing and i could, but i didn´t get the ack back. The same happened when i tried to read registers, i dont´t get the data from the inverter.
To do this i am using the msg instruction on rslogix 500.
The parameters i used are:
MB command: 06 write holdind registers
data table address: N10:0
size in elements:1
data:16 bits
message timeout: 2
MB data address: 1
Local bridge addr: 1
the error i get is: message timed out in local processor (37h)
Does someone knows what may be happening???
Thanks!!
size in elements:1
data:16 bits
message timeout: 2
MB data address: 1
Thanks!!
