modbus protocol opc server
ayman metwally
Dec 2003
Cairo
258
hi
If the manufactor of the plc says that his PLC supports modbus protocol , does that mean that I can use any ( modbus ptotocol OPC server ) with this PLC to make SCADA/HMI system ?
for example :
master-k series PLC from LG ( it supports modbus protocol )
opc server : the modbus opc server that matrikon offers .
Can these two things work together in order to design a scada software ( I desighn it by VB6 with some Activex controls)
thanks for your replies .
I can't think of a reason as to why your solution would not work...Good luck...
I assume that the master-k series PLC from LG can be a SLAVE (sorry for not being politically correct after viewing a certain thread...).
Also just check though, is it modbus RTU or ASCII protocol...
Hello Guys, I have been trying to study a Machine that have Omron 3g3mv VFDs that is controlled by CJ1m CPU and SCU41-V1 communication card. The...
480
Hello Guys, I have a packaging machine in the company that I work for that have 8 Omron VFDs (3G3MV ) that are controlled via Modbus with CJ1M...
649
Dear guys, I have a software that sends data to PLC using modbus. I want to connect my software with siemens plc, how can i do that?
19
4,725
I am finally lucky enough to work w/ an actual high level programmer. I can follow a tag from the pnp junction up to an hmi. He knows the other...
20
5,748
Hi! Please share the MODBUS protocol code for the subject Regards
2,425
