MODBUS TCP gurus
cjh
Mar 2003
Cumming, GA
235
Question about MODBUS TCP gateways:
If you send a unit identifier value of 0 to a MODBUS TCP gateway, should you wait for a reply?
The spec. is kind of confusing here to me. I know that in a serial MODBUS RTU network, you don't wait for a reply when you do a broadcast but the MODBUS TCP spec. says that a unit identifier of 0 is valid either when you are sending a message to a gateway or to a standard MODBUS TCP server device.
It probably seems trivial but the throughput will definitely be affected if I wait for a reply and no reply is forthcoming (have to wait the entire timeout period). I know that I can buy a gateway to find this out but I was hoping someone here might know the answer and save me a few bucks...
Ok...no luck with that question...
<So much for saving a few bucks...>
How about this? For you guys that use MODBUS TCP gateways, what brand and model do you use? And if you know the price as well, that would be great.
Thanks.
I have a PH meter that I am trying to bring its data into 1756-L81. I have downloaded the Rockwell MODBUS AOI kit, but I am not sure if I need to...
168
Hello gentlemen, Im working on a small project on TIA Portal, about establishing a Modbus TCP connection between my ET200SP plc and a socomec...
310
If a device has Modbus RTU over serial and Modbus RTO over TCP and Modbus TCP then there is a difference between Modbus RTU over TCP vs Modbus TCP...
485
Hi There. I have PC to get few tags from PLC into C# windows forms application. What is the best and fastest way? I could not find Omron in...
283
I contacted Hach and bought a kit they recommended for a customer to add Modbus TCP capability to his Chlorine Analyzer with a SC4500 controller...
232
