Modbus TCP/IP from CLX to DCS via wireless
gakpapa
Mar 2008
jakarta
34
Hi Guys,
need your advise here...
I wanna communicate CLX to a DCS Modbus TCP/IP
here's the configuration:
MVI56-WA-PWP ---wireless--- > Prolinx-WA-PWP ---> DCS Modbus TCP/IP
Since i don't have DCS, i use CLX with MVI56-MNET (assumed as DCS)to do simulation.
Does any of you ever do this kind of configuration?
i've configured MVI56-WA-PWP and Prolinx as attached file
but, still cant communicate
i really appreciate your help
roe
  • Prosoft Configration BUilder.zip
You're dealing with brands I've haven't used, but I'll describe my approach:
I connect two PCs, point-to-point, using the ethernet radios. If I can't browse the other PC's directories (sharing enabled) or do a file transfer, point-to-point with the radios, then the radios aren't setup right.
It is my impression that even ethernet radios have to be configured for their functionality: master or slave, access point, bridge, repeater, whatever.
I find it far easier to 'prove' radio functionality with 2 PCs first, than with devices that need to be programmed to execute a read or write function via a comm (ethernet) port.
Once the radios are working, then I'll substitute a PLC for the PC at one end and dink around until I can get the PLCs' development software to talk to the PLC. That establishes communication from PC to PLC over ethernet radio.
Then I'll run a Modbus tool (master or slave, depends) on the PC to read or write a value via Modbus TCP to the PLC.
Then I put an ethernet switch on the PC end so I can connect the 2nd device (DCS) in your example and the PC at the same time. Keeping the PC on the link allows me to confirm that I still have a viable communications link, when things inevitably don't work on the DCS.
It's a step-by-step, build it up procedure.
Dan
I have got a Clx processor 5561 that I want to be able to communicate with about a dozen heating/cooling units. Unfortunately the only...
3,214
:mad: Having trouble with REDLION DSPSX000 with optional ethernet card. Trying to talk to 7 GE multilin 750 and 745 protection relays via Modbus...
3,954
I have a PH meter that I am trying to bring its data into 1756-L81. I have downloaded the Rockwell MODBUS AOI kit, but I am not sure if I need to...
164
Hello gentlemen, Im working on a small project on TIA Portal, about establishing a Modbus TCP connection between my ET200SP plc and a socomec...
310
If a device has Modbus RTU over serial and Modbus RTO over TCP and Modbus TCP then there is a difference between Modbus RTU over TCP vs Modbus TCP...
485
