Modbus TCP/IP in Cimplicity
puravdagli
Nov 2006
Michigan
58
Hi All,
This is my first experience with Modbus TCP. I need to read data from 2 Ashland ORP panels (I dont think the type of device really matters) into Cimplicity v6.2.
I know Cimplicity has a built in Modbus TCP driver but I have heard people having doubts about its robustness and reliability. Also, I am not aware of the amount of configuration involved. The other option I have is the Kepware Modbus TCP driver. Again, I do not have enough information about this to make an educated comparison. Please suggest.
Any help is appreciated.
Thank you.
You don't mention your target processor, but, the PACSystems controllers have Modbus TCP channels as standard.
Refer to G.E. GFK-2224D, Chapter 7.
Hi All, I'm using AB plc 5370(Modbus TCP slave progm type) with GE cimplicity scada V8.1. For DI,DO,AI communication is working good. But, I...
2,561
hii i have a servo controler mp2300 from Yaskawa. i want to connact with cimplicity hmi through modbus tcp protocol. i open mudbus tcp request...
6,332
I have a PH meter that I am trying to bring its data into 1756-L81. I have downloaded the Rockwell MODBUS AOI kit, but I am not sure if I need to...
176
Hello gentlemen, Im working on a small project on TIA Portal, about establishing a Modbus TCP connection between my ET200SP plc and a socomec...
313
If a device has Modbus RTU over serial and Modbus RTO over TCP and Modbus TCP then there is a difference between Modbus RTU over TCP vs Modbus TCP...
501
