Modbus to Canopen
WainDude
Aug 2010
Edmonton
26
Anyone have any experience using a modbus to can bus converter, basically I have can master that I need to pull analog data from a modbus slave, either rtu or tcip. I have a icpdas i7232 but the documents such big time, I would like something easier to set up. Any thoughts
HMS Industrial Networks has both CANopen to Modbus RTU and CANopen to Modbus TCP/IP.
http://www.anybus.com/support/support.asp?PID=107&ProductType=Anybus Communicator
http://www.anybus.com/support/support.asp?PID=465&ProdType=Anybus X-gateway
and they are both easy to set up, basically all you need to do on the gateway is to set up what registers you need to read/write.
With CANopen to Modbus RTU, there is a configuration tool and with the CANopen to Modbus TCP/IP there is a built in web server.
//Patrick L
Hi folks, I have a Controllogix in communication with a zigbee coordinator using Logix AIO for modbus tcp. This zigbee coordinator have 3 slaves...
44
80
Hi Everyone, i was hoping for a little help with this module. i have data that needs to be read from a different plc through the Modbus plus...
243
I have a PH meter that I am trying to bring its data into 1756-L81. I have downloaded the Rockwell MODBUS AOI kit, but I am not sure if I need to...
181
Dear All, i am trying to connect Danfoss inverter with s7 200 cpu 226.but microwin shows following error at DATA Ptr.i assigned different VB...
51
