modelling of water tank temperature
khayabi
Jul 2011
East Java
Hi guys,
these days, I was trying to get water tank temperature model which is used in genetic algorithm to tune PID parameter.
The heater in the inside of the tank. I need your help to get the modelling system of water tank temperature. Thanks :site:
Please comment...
I have a good SOPDT model for temperature. Implementing it on a PLC would be a little math intensive and it requires a queue or FIFO to simulate the plant dead time. What do you want to run the model on? I have a very good SOPDT temperature control simulator on-line most of the time now.
actually this isn't PLC case. I need the modelling system to apply in Qt (c programming). I found water tank modelling in this forum. May you can tell me about how to get modelling of water tank temperature ??
107
Hello guys, it's time to talk about modeling and simulation again. I've been doing some research and saw different models. I noticed that in...
7,705
I'm starting a new PLC control project and would appreciate some guidance on how to do things right. I need to model/describe what is it that I...
2,710
Hi, I am a little nervous when I write this, it can be the start of a timeconsuming involvement. But it has been on my mind for a long time. And...
5,884
111
