Modicon 484, how to load timer Reg value?
jbklyman
Apr 2005
Chicagoland area
Hey, any PLC Dinosaurs out there? I'm on a mission to convert all the remaining Modicon & Maxitron/Telemechanique systems over to A&B SLC 500 or PLC 5 systems.
Most of the conversion is pretty straight forward, but I've come across a Modicon timer instruction that is pulling its preset time from a memory register, but I can find no place in the code that initializes it. There are some BCD thumbwheel switches that load two other timers (I have found the network section that loads these memory locations) but nothing for the other two. Any ideas on where to look for this stuff, or if these is some firmware coded values that may be in use?
I'm wondering if the original programmer circa 1993 (he is dead now) simply loaded the timer values via the programmer and simply left it as a retentive register value as job security. Hey you don't necessarily have to be a good programmer to work these things.
Thanks for any help
Jim Klyman - BP Chemicals Naperville IL
Dinosaurs
Hi , I dont speak english very well
I worked whit this PLC´s many years ago.
I dont understand exactly what you nead but ...
May be there is no an instruction that is pulling its preset time from a memory register , because it´s no necesary (the value is the same always).
May be this register is loaded by communication.
The timers preset needs a constant or a holding register.In this register you have to put the needed value.
Good luck
Hi guys, I am trying to convert a Modicon 484 program to a 984 program using Taylor Soft 1.03. I am having a little trouble and was hoping some...
2,755
Hello All, I need to upload a customer's program from their Modicon 484. I am no expert with the 484 series but it is my understanding that I...
3,149
We have four Mod 484 controllers that, when using a HH P464 won't switch to run mode. The 484's are not connected to any I/O rack. Is there a...
2,291
Gents, Does anyone know where I could find a programming manual for this guy. tks
5,057
We have a old 484 and wanted to add a timer to delay a condiction in a network We have the ldp software but no manuals can anyone tell us where to...
1,792
