Ramil
Guest
R
Customer has Modicon 884 CPU with below configuratoin:
1. P800-03 Power supply
2. P884A-200 CPU
3. B825-016 16 point 24 Vdc input module (8 nos.)
4. B824-016 16 point output (8 nos.)
5. H819-003 primary frame
6. H819-000 secondary frame.
Problem:
The RUN led is not glowing
Battery OK - Green color is lit.
I belive that when battery ok led green is steady it means battery has gone.
Also RUN led is not lit. which means the program might have erased because of failed battery.
I am seeing this PLC for my first time today only.
Our customer has P190 with him. He also showed me 4 nos. of cassette tape. one was written as configuration software for 884 branded Gould and other also Gould tape. The third cassette i belive is the backup program. I really donot know what the fourth caseette is as nothing was written on it.
He had called me to put his PLC to run mode. I am a small sized integrator - i work on my own. I had previous experience only with AB PLC. But now i donot want to loose this customer and his money.
If you can help me to find the manuals for this or tech. support for this product would be of very much help.
Customer showed me (hardcopy)printout of ladder logic program. I also belive that one of the casette might have backup program.
My question is how can i transfer program from Casette to 884 and what hardwares/cables are requied. Customer showed me P190 but his PLC guy has left the company long time before and hence they donot have any idea of which casette to run or which cable to use.
also where to find manuals for P190.
Many thanks for all your support.
2. P884A-200 CPU
Problem:
