Modicon As-b883-201
nickguok
Sep 2007
Puchong
Hi, can anybody help on how to configure the RTD input module?
the PLC that used is 984, programming software is Modsoft 2.5, and what i'm doing is i'm going to replace a faulty module with a new one. (Replace same model module)
1) is there any steps that i should do before / after replacing the new module?
2) once i've replaced the new module with the old one (without changing its software and program or configuration), i just slot in the new module in the old slot. the reading that i obtain was much more higher than before. (previous reading was 15 - 25degC, after replacing, reading was 104 - 120 ) is it the new module need to change the unit that it takes?
3) how can we know what unit is that module using? How to change?
HELP is needed urgently.
Thank u!!
Nick
Anyone have experience wiring the terminals and setting up this module? I'm in the rack with a 984-784 CPU using ProWorx. What do you enter into...
4,156
Can this module be removed and inserted under power? Thanks!
1,805
Hello All, I am stumped on how to convert a %MW to a %MF using Machine Expert Basic and a Modicon M221. The help files show a word to a double...
63
A lifetime ago I built a couple systems with Modicon Micro84 controllers that are still running. But today one of those died and they reached out...
82
Everything was working fine, but suddenly CPU went into error mode, and the ERR and TER LEDs lit up. Now I can't download or connect with the PLC...
68
