Modicon CPU 113 03 Communication??
D18
Sep 2012
Ontario
Hi, we have a PLC, CPU 113 03 and we're having
trouble communicating to it via Proworx32.
I'm not sure of any com configurations from
the previous people in this position, we have
basically been left to figure it out on our own.
We are attempting to connect through the Modbus
DB9 connector, is this just straight RS-232 protocol,
and what cabling is required to establish a connection.
We have a MBP USB to serial converter box, as well as
a generic USB to Serial converter at our disposal.
We just can't seem to get anywhere.
Thanks,
T
They use both, I know if you don't have them connected then the cable will not work. You can get by not using pin 1&9 but all others must be used. If you build a cable pinned out like the diagram in my last post it will work. Against I'm not familiar with Proworx 32 but in concept you go into your unitelway drivers to set the port, baud, etc.
Hi everybody , I hope all friends in best situation , I needs your help to solve my big problem with Schneider PLC network i working to...
4,888
Modicon Quantum CPU 113 03 Hiii Recently i joined with the new project. Here using the Quantum PLC's 113 03 with LookOut SCADA. Totally 7...
2,353
Modicom CPU 113 03 I need to program a Modicon 113 03. Where I can find the software? Seems it is a very old CPU. What is the extension file...
6,624
When i read the specification of 140CPU43412A i observe that as remembered in specification 1. Local i/o : Maximum i/p and o/p words are 64 in...
502
Main rack contained power supply 140cps52400 and 140cpu43412A and RIO HEAD 140CRP93100 in addition to another I/o cards . Another remote rack...
1,869
