Modicon m430 and momentum as modbus slaves
IdealDan
May 2017
MA
480
Hi Guys,
Does Modicon M430 and Momentum Controller have In-Built Modbus SLAVE functionality or do I need to add a Modbus card to them? I'm checking manuals but could not find SLAVE info.
Regards
M340 model with the built in ethernet port (part number has 2020 in it) yes. No need for additional NOE or NOC card.
Not sure about momentum.
Hi, M340 cpu2020 has dedicated modbus rj45 socket. Master or slave can be chosen.
Momentum with rs485 "top hat" also modbus rj45 socket also has master/slave functionality.
Use Cat 5 patch lead into m340 modbus port. Cut off the other plug and terminate pins 4 blue and pin 5 blue/white (rx/tx) into your network for rs485 2 wire.
Why on earth are you using modbus RTU for new installs?
Go Ethernet. You'll save the cost of the network switch with the reduced troubleshooting time.
Actually, some of the slaves on the same network have only RS485.
eg Gas Chromatography etc
Really?
Will this work?
Or should there be a converter kind of?
The 342020 processor is Ethernet and RS485, the 341000 and 342000 is RS485 only, both presented on RJ45 socket, wiring details in the manuals, can be slave or master
@saffa, we see it a lot as a means of network separation, i.e. SCADA to BMS comms. etc.
Quote:
Really?
Will this work?
I assume you would need to terminate the modbus cable into your network via junction box and terminals? Thats, how I have done it in the past.
Everything was working fine, but suddenly CPU went into error mode, and the ERR and TER LEDs lit up. Now I can't download or connect with the PLC...
45
Hello All, Was hoping I could get a little help with Modicon ladder logic. This is the first time I have seen Modicon logic and currently trying...
271
I have a 170AAO92100 card that I am interested in using as a 10 volt output. Is there setup that I have to do in order to change output or simply...
86
Hi, Seeking consultation on an implementation matter, and have a question about Modicon Compact 984 communication through RS485: Three Modicon...
219
After updating a panel, I inherited another PLC for my "learning lab". It's a Modicon TSX Micro. I've not worked with a Modicon PLC yet, so I...
136
