Modicon M580 and Powerflex question
secs
Aug 2015
Office
65
Hi all. Having had to change jobs due to the recent Covid stuff has thrown me a curve ball. I write my own software and have played with Rockwell and Triplc stuff but am self taught in everything I do. I need some help.
I have recently changed jobs and trying to get my head around Unity Pro etc using Youtube.
I have a Modicon M580 and a Powerflex 525 VSD
Stumbling around (and there is no other way of describing it) I can see the VSD block and the associated code etc for the speed control.
So my basic question is:
The PLC and VSD comminicate over ethernet. I can see the VSD unit in the DTM browser etc. I need to increase the maximum speed of the VSD. I have changed the max speed in the VSD itself but I cant get the unit to increase speed. The functional block etc shows 100 as the speed and I was assuming that was sending a 100 to the VSD meaning 100% of the max speed setting on the VSD but now I am not so sure.
My above explanation using the best but how does the unit send the speed? Is it a 0-100% of does it send say a 50 for 50 hz etc. If I can work that out, I can perhaps find where the reference is coming from. I have changed parameter 44 on the power flex but I am now also wondering if I have missed something.
Hi all, I'm really new to this. I need to export the Modbus register mapping from a Modicon M580 through Control Expert for the registers that...
966
We are now planning to upgrade from Quantum 140CPU11303 to Modicon M580. The software protect was written by Proworx NxT (.DCF). Is it possible...
1,013
Hi, Does anyone know if programming a Modicon M580 is basically the same format as an M340? Also do they use the same software package? Thanks...
1,783
I need to convert some Siemens PLC logic using Siemens TIA V16 to Modicon M580 logic. Is there a tool out there that will get me started? How...
2,703
How do you go about implementing, on the M580 PLC, how many days, hours, minutes before a predefine event in the future? The RRTC_DT yields the...
1,826
