Modicon Quantum -> GE Fanuc RX3i Comms Qn...
sikeoboy
Jul 2008
Vancouver
Hello,
Can anyone advise me which is the best way to communicate data between a Modicon Quantum PLC and a GE Fanuc RX3i CPU?
Are they communicate with each other directly over ethernet? or does the GE Fanuc PLC need to have a Modbus comms card fitted to it with comms then happening over Modbus?
Thanks,
Rob
You have three options:
1. serial comm module (this is what you want to avoid)
2. using the serial ports (one RS232, one RS485) from the CPU and work with COMM_REQ
3. using Modbus TCP via separate Ethernet modul (probably, it's already there)
Joern
Another alternative and more expensive idea would be to use a redlion datastation or G3 hmi to handle the transfers.
Hello All, Was hoping I could get a little help with Modicon ladder logic. This is the first time I have seen Modicon logic and currently trying...
273
Hi There, I have a Modicon Quantum PLC, there is a alarm on display "noConfig" its happened after power failure, I have gone through manuals...
655
When i read the specification of 140CPU43412A i observe that as remembered in specification 1. Local i/o : Maximum i/p and o/p words are 64 in...
500
Main rack contained power supply 140cps52400 and 140cpu43412A and RIO HEAD 140CRP93100 in addition to another I/o cards . Another remote rack...
1,867
System Details: We use hot redundant Modicon Quantum PLC with dual redundant communication having Remote IO racks (using CRP + CRA cards and...
777
