Modicon Quantum Programming Software
Jul 2007
Kiruna
600
Hi there,
Anyone familiar with Modicon Quantum PLCs?
What programming software is required for the 45PLQUA series and what is the latest supported OS need to install?
Never used Modicon before and have a couple of small modifications to make to a system.
Thanks in advance.
I've only used the older modicon quantum PLC's, but they used Proworx 32. Maybe start there, if that's not correct it might at least lead you in the right direction.
Thanks ASF,
That's a good starting point. This system was delivered in the early 2000's. Would you by any chance recall the OS you had this software installed.
Trying to establish if its worth the effort or just hire a contractor with all the tools ready.
The version I dealt with (this is back in 2010-2011, but the PLC's had been around much longer) was installed on Windows XP. Shortly before I left that role, the workstation was upgraded to Windows 7, but they had to maintain a Windows XP VM to run Proworx 32. So, most likely you'll need XP.
I'm told there is a third party software package available, reportedly much better and more stable than Proworx 32. It would probably run on a newer OS. But I don't know the name.
Hello All, Was hoping I could get a little help with Modicon ladder logic. This is the first time I have seen Modicon logic and currently trying...
271
Hi There, I have a Modicon Quantum PLC, there is a alarm on display "noConfig" its happened after power failure, I have gone through manuals...
653
When i read the specification of 140CPU43412A i observe that as remembered in specification 1. Local i/o : Maximum i/p and o/p words are 64 in...
497
Main rack contained power supply 140cps52400 and 140cpu43412A and RIO HEAD 140CRP93100 in addition to another I/o cards . Another remote rack...
1,866
System Details: We use hot redundant Modicon Quantum PLC with dual redundant communication having Remote IO racks (using CRP + CRA cards and...
777
