Modicon - Remote IO Faults
leonlai
Jun 2011
WA
96
I got Remote I/O Faults multiple times when I was running the system,
I've check manual and lead no sense to me how to fix.
System run for a while and PLC (Modicon M1E) just STOP because
Red light on I/O
Flashing on RUN
Yellow on BOTH of ERR and MB1
The only thing I do is use Unity Pro XL get inside PLC, hit RUN and everything back to normal. But I dont want it happen again, any idea that I can prevent it happen or what causing it ?
WHen I run Diagnostic, all I got is "Remote IO fault - System Alarm - %S118"
any idea ?
WHen it fault out last 2 times, I did take out old cable, plug in new cable, and happen again. So I dont think it's the cable, I check the connection between cable and modules are all tight !
anything else I should look at !? Like config or conflict computing !???
System Details: We use hot redundant Modicon Quantum PLC with dual redundant communication having Remote IO racks (using CRP + CRA cards and...
792
Hello I have a system using a Modicon M340 with onboard Modbus and Ethernet. I want to add some remote IOs and given that: 1. Schneider's...
7,879
I need some help. I have established communication between the Modicon Premium PLC, using PL7 Pro ver 4.5 software and Adam 6251 remote I/O...
3,846
We are having another Modicon issue, this time it's a Modicon 584 with a remote I/O network and no local I/O. Originally, the PLC CPU was dropping...
4,894
I am trying to setup remote IO drops. I have found the problem, but just trying to understand why it happens the way it does. Situation 1: Using...
3,257
