Modicon 584 remote I/O trouble
Tech7
Nov 2005
Southeast Michigan
32
We are having another Modicon issue, this time it's a Modicon 584 with a remote I/O network and no local I/O. Originally, the PLC CPU was dropping out of "RUN". Using the old Proworx NXT software we were getting an error 20, "CPU Bad". Tried reloading the program anyway and could not resolve this problem. Decided to change out the entire PLC nest(the nuclear way)containing the CPU, memory expansion, I/O card etc. Once we loaded the program into it(including the configuration in traffic cop), we were able to get a run light. The only problem now is it will not communicate with the J200 I/O expander unit so none of the remote I/O will respond. The only light on the J200 is the power light. The Xmit and Rcvr lights are not lit. Since the new main nest was just recieved from rework/rebuild, we have ordered a new J200 remote I/O expander module. I am hoping this will fix the problem. Am I on the right track or is there something I'm totally missing? Modicon Gods, please help.
T7
I have a ProWorx32 file that includes values entered into the 600,000 Extended Memory Areas, but I am not seeing the XMWT, XMRD instructions to...
1,143
It's been so long since I've been inside of Modicon. Hope you can refresh my memory. Is it required to declare specific 400,000 addresses as...
1,509
Hello, Can anyone please tell me in regular language what the fault code dEAd40 on a Modicon/Gould 584 controller actually means and how to...
1,327
I have to restart a production line that uses a Modicon 584 (1600+ I/O) and a Modicon 684. I have not worked with modicon before. Can these PLCs...
2,314
Can someone tell me what state the outputs are in when a stop command is issued to a Modicon 584. Do they remain in their last state or do they...
2,909
