Modicon Gould 584 Error Code dEAd40
ntop
Dec 2018
Canada
Hello,
Can anyone please tell me in regular language what the fault code dEAd40 on a Modicon/Gould 584 controller actually means and how to resolve it?
I don't have any more information or access to the program, other than someone I used to work with called me and asked if I might be able to dig up some info on what this fault code actually means.
Thanks in advance.
Some screenshots from user manuals:
Looks like they should first replace the I/OP board. If that doesn't cure the problem, replace the CPU board. I don't remember enough about the 584 to be able to say whether replacement of either of those boards will mean they also have to download the program after the replacement.
If you google "Modicon 584 error codes" the first item is a link to the maintenance manual.
Hi Steve,
Thanks for the response.
I tried to google I/OP Board and wasn't able to come-up with anything....
Do you happen to know what this is? Is it an I/O board which is built into the controller? Is it referring to an I/O board which is external? I/O power board?
I did a search on a few variations of I/OP in the user manual and wasn't able to identify anything..
Thanks.
It has been more than thirty years since I last worked on a 584. Chapter 2 of the maintenance manual describes the I/OP board as well as the rest of the cards in the main processor rack. It looks like all of the "dEAd" fault codes have to do with the main processor hardware and I think "dEAd" should be taken literally rather than interpreted as hex characters. The processor is "dEAd" until you can correct the fault.
Hello all, I have a old Gould PC0085 plc that I am trying to program. Have not used one of these in years. I am using the PP0105 programmer and...
5,436
Does anyone have an instruction manual for this PLC, particularly for use with a hand held PP0105 programmer which I have access to?
3,543
Hi! I'm new to the site and wonders if anybody here have worked with Modicon C484 from 1980 (or equivalent). The question is how the powerflow in...
2,560
U
I am looking for the pin-out of the Gould Modicon Micro 84 comm port (programmer port) that is for the P370 programmer anyone have that info...
3,474
Unregistered
U
Hi, I need some help in find information on two plc that are in a machine which I need to modify, the plcs are Modicon micro 84, M84A-002 and...
4,911
