Gould/Modicon PC0085 Programming Help
Scooter
Apr 2002
Michigan
143
Hello all, I have a old Gould PC0085 plc that I am trying to program. Have not used one of these in years. I am using the PP0105 programmer and have no manual.
It is a 3 card rack, 2 input 1 output(cards).
My questions:
The input cards are addressed: first card 0-7 the second card 10-17, my third card is an output card and assumed it would be 20-27.
So is this correct or is the output in a different range?
The plc will accept a simple one rung program and go into run but I get no output. The programmer shows the output on but no led lit on the card. I have swapped output cards and no luck. All the little ribbon cables that connect the I/O cards are good and have the dummy jumper in the last plug on the last card.
Also is there a "end" command that should be at the end of the program?
As I said I have no manual and am working from memory.
Thanks...
I have a pdf file of the manual if you would like to PM me an email address, I will send it to you. It's about 6meg's. If you would rather that I upload it to yousendit or something like that with a link, let me know.
From the manual, page 2-1:
The locations within the rack are interchangeable with input or output. That is, no restrictions on physical or slot locations within the rack.
INputs start at 000-007 for the 1st slot they are in, left to right, 010-017, 2nd slot, and so forth. OUTputs numbering start at 110-117 for the 1st slot they are in, left to right, 120-127 for the 2nd slot and so forth.
Page 4-81 says that an END (F-40) instruction will automatically be put in as the last instruction. You can however insert one earlier in the ladder for testing a partial program, but should be removed for normal use after testing.
Does anyone have an instruction manual for this PLC, particularly for use with a hand held PP0105 programmer which I have access to?
3,544
Hello, Can anyone please tell me in regular language what the fault code dEAd40 on a Modicon/Gould 584 controller actually means and how to...
1,327
Hi! I'm new to the site and wonders if anybody here have worked with Modicon C484 from 1980 (or equivalent). The question is how the powerflow in...
2,561
U
I am looking for the pin-out of the Gould Modicon Micro 84 comm port (programmer port) that is for the P370 programmer anyone have that info...
3,474
Unregistered
U
Hi, I need some help in find information on two plc that are in a machine which I need to modify, the plcs are Modicon micro 84, M84A-002 and...
4,911
