Modicon TSX micro bit sum query
Baptie
Jan 2012
Aurshire
Pure mind boggled at this one, can’t seem to figure it out.
NO contact with - %M130(%MW11)
How is this possible?
Is the %MW11 0 it’s logic 0, 1 it’s a logic 1?
It's a while since I worked on TSX but I think this is an offset so if the value of %MW11 is 0 then the value of %M130 is used . If % MW11 is 1 then the value of %M131 is used and so on . Other contributers will correct me if I'm wrong .
Paul
it is indirect addressing.
It should not be less than 0, it will cause inder error warning on program side.
(it was system bit 16 or 18 maybe and you can select with another system bit if CPU is halted or stays at run)
After updating a panel, I inherited another PLC for my "learning lab". It's a Modicon TSX Micro. I've not worked with a Modicon PLC yet, so I...
136
Hi All, i have PLC Modicon TSX 3722 Micro i need to know where should i put the socket of programming cable on Ter or Aux port. and i see the file...
1,636
Is it possible to send and receive data with a custom protocol communication for reading inputs and setting outputs? for example via TER...
1,361
Dears, I am trying to communicate with modicon TSX3721001 using TSXcUSB485 cable i purchased the cable from a local Schneider distributor and...
6,887
Hello,please I have need a Firmware Updates support for Modicon TSX Micro 3721
1,780
