modicon
You can check that the communications cable doesn't run near any power lines. I've had a couple of problems with intermittent communications because of this.
Other than all the basics of shielding, loose connections/vibration, cable too long (RS232 >100'), the only thing I have experienced is in home-made cables and bad solder joints, If yours is a molded plug DB9 on both ends then you are probably ok on that issue.
Brian.
PS -- Is it happening on the bootup of the panelmate or the PLC, Obviously if you shut down and reboot the PLC you will get LOC.
Everything was working fine, but suddenly CPU went into error mode, and the ERR and TER LEDs lit up. Now I can't download or connect with the PLC...
51
Hello All, Was hoping I could get a little help with Modicon ladder logic. This is the first time I have seen Modicon logic and currently trying...
285
I have a 170AAO92100 card that I am interested in using as a 10 volt output. Is there setup that I have to do in order to change output or simply...
90
Hi, Seeking consultation on an implementation matter, and have a question about Modicon Compact 984 communication through RS485: Three Modicon...
241
After updating a panel, I inherited another PLC for my "learning lab". It's a Modicon TSX Micro. I've not worked with a Modicon PLC yet, so I...
141
