Moeller easy cable (EASY-PC-CAB)
pufek
Mar 2013
Zagreb
I desperately need cable pinout for Moeller easy 822 DC TC!
Can anybody help me?
I could not find a wiring diagram for the Moeller EASY-PC-CAB cable (serial cable to connect EASY control relay to a PC computer). It is the same cable as the Eaton EASY-PC-CAB, but apparently the pin-function diagram is a company secret. Too bad.
The cables might be the same but I saw two different part numbers on the Allied Electric website. One is for the 500/700 series, the other is for the 800 series. I also searched to find a wiring diagram with no luck, the same as Lancie1.
Link to catalog page:
http://www.alliedelec.com/catalog/pf.aspx?fn=1421.pdf
Here is a Snip from that page:
Snip....
70056867 EASY-PC-CAB EZ500/700 to PC Cable
70056868 EASY800-PC-CAB EZ800 to PC Cable
We were looking at attaching a printer to an Easy 819 using the SP serial protocol instruction. I got the attached pin out from Moeller.
friends, plz give me cable pint out for Moeller EASY 800 USB CABLE . my old cable broken, want to repair that. thank you all
1,943
As the title - are there any? What I mean by this in particular is special flashing bits or always on/off bits and maybe first scan. Not my...
2,051
hello Gentelmans, Is there a first scan bit in Klockner Moeller EASY PLC?
2,802
Hi guys. How do I on Power up set this plc to a spesific rung without push button?:scratch:
1,759
necesito las conexiones del cable entre el plc y la pc y el programa para hacerlo.El PLC es Moller Easy 412-ac-rc. Gracias
4,657
