momentum "170 AMM 090 00"module Interbus address
gherz817
Oct 2005
PHILIPPINES
58
Somebody could help me out my problem.
I have a momentum cpus and interbus module "170 AMM 090 00"
I search internet but i could find a site that can
help me how to address this module in my concept ver 2.6XL program.
Thank you very very much..
gherz817
thanks leon. this is my first time of momentum. Can explain me how can i get DI, DO, AI and AO addresses out out 3xx and 4xx address?
The help file doest exactly give example.
thanks in advance..
Creat new project. Configure PLC Type. Open I/O map. Press key "Insert". Add in drop 1 IO base under controller adapter. Add in drop 2 all IO Base under communication interbus adapter.
For 170 AMM 090 00:
The I/O base must be mapped as five contiguous input words and five contiguous output words, as follows:
Word Input Data Output Data
1 = LSW Value, input channel 1 Parameters for input channels 1 ... 4
2 Value, input channel 2 Parameters for output channels 1,2
3 Value, input channel 3 Value, output channel 1
4 Value, input channel 4 Value, output channel 2
5 = MSW Discrete inputs Discrete outputs
See in Concept Momentum Help -> I/O Base Descriptions -> 170 AMM 090 00Analog 4 Ch. In / 2 Ch. Out Module Base w/ 24 VDC I/O Pts -> I/O Mapping
I have a 170AAO92100 card that I am interested in using as a 10 volt output. Is there setup that I have to do in order to change output or simply...
100
Hello Folks, Has anyone configured a Momentum high speed counter on Unity 13.1. We need the wiring diagram for Momentum High speed counter and...
89
Trying to identify the Modbus RTU registers that are in use in the Function block programming in the PLC program. I have a Kohler DEC 550...
170
I am not too familiar with the Schneider family of PLCs .. but I have a client that wants to upgrade from a Momentum to something newer. They had...
2,476
Hello All, I have old momentum plc with concept software on it. Its using in filter plant. so somehow all of sudden all effluent valve went to...
1,202
