Momentum/Concept 2.6/Scan times
(8{)} ( .)
Apr 2004
Israel
625
Hello All,
I have a customer who uses Modicon Momentum PLCs
programmed with Concept 2.6. The scan times on these
controllers is beyond anything I've ever seen in a PLC. Small
units with < 100 I/O with scan times > 200 ms.
I'm trying to find a document that lists instruction scan
times and the relative efficiencies of different languages in the Momentum.
For example, I know that these controllers are not the most efficient at doing floating point math.
I've done all of the searches that I know how to do. Can
anyone out there point me in the right direction?
Thanks,
(8{)} :) .)
(Yosi)
Trying to identify the Modbus RTU registers that are in use in the Function block programming in the PLC program. I have a Kohler DEC 550...
160
Hi..I am working on a project involving Momentum PLC 171CCC98030. I am doing its programming in Concept 2.6 SR7 (Demo Version) . I have following...
1,825
Hello - I have a client with TSX Momentum Processor Adapters, 171-CCC-980-30. Per schneider they are IEC, and I need CONCEPT to program them. I...
3,877
Our company uses Schneider Momentum 171CCC96020 PLC's with our production system to capture press counts. I am using Concept 2.6XL SR6. When we...
4,099
Pretty new at Concept (AB guy). I have an XXMIT that handles communications with a dozen remote RTUs. I want to monitor the Error and Done bits...
1,722
