Modicon Momentum Concept XXMIT
bluenoser337
Apr 2003
Nova Scotia
391
Pretty new at Concept (AB guy). I have an XXMIT that handles communications with a dozen remote RTUs. I want to monitor the Error and Done bits to come up with individual comm alarms for each site. I set it up to compare the site numbers with the site being polled, and then the Error bit will increment a counter, and the Done bit resets the counter (one for each site). If the counter finishes, the comm error bit turns on. Problem is, sometimes the number of the station being polled and the error/done bits appear to be out of sync. I think it must be a scan thing and I've tried moving things around, but no luck. I wanted to compare the 3rd word in the MsgIn structure at the XXMIT, as that is the station number but it won't let me put a structure element in an Equal instruction. Is there a way to use a single value from a structure? Thanks!!
I have a 170AAO92100 card that I am interested in using as a 10 volt output. Is there setup that I have to do in order to change output or simply...
86
Hi Guys, Does Modicon M430 and Momentum Controller have In-Built Modbus SLAVE functionality or do I need to add a Modbus card to them? I'm...
3,179
First time with Unity Pro and a new Unity CBU (Central Brocessing Unit??):) Trying to read the RTC but having no luck at all. Can't be that...
2,215
I have a customer who has a Momentum PLC in a machine. There is a soft start that runs a large hydraulic pump, and about 15 solenoid valves that...
2,436
Hey, gentlemens! I have PLC Modicon Momentum 171-CCC-96030 and ModBus registers list. I need connect to this PLC by ModBus TCP and reading...
5,563
