Modicon Momentum Unity CBU RTC
bluenoser337
Apr 2003
Nova Scotia
391
First time with Unity Pro and a new Unity CBU (Central Brocessing Unit??):)
Trying to read the RTC but having no luck at all. Can't be that difficult so I must be missing something simple.
Thanks! :geek:
it is years, when I programmed momentum PLC and it was Concept programmed.
On concept time was on some %4X registers
Try: RRTC or RRTC_DT -blocks, it looks like that momentum don't use system words to this
I have a 170AAO92100 card that I am interested in using as a 10 volt output. Is there setup that I have to do in order to change output or simply...
86
Hi Guys, Does Modicon M430 and Momentum Controller have In-Built Modbus SLAVE functionality or do I need to add a Modbus card to them? I'm...
3,159
I have a customer who has a Momentum PLC in a machine. There is a soft start that runs a large hydraulic pump, and about 15 solenoid valves that...
2,434
Hey, gentlemens! I have PLC Modicon Momentum 171-CCC-96030 and ModBus registers list. I need connect to this PLC by ModBus TCP and reading...
5,557
We are looking into purchasing a modicon momentum PLC that will control a slave using Modbus TCP over Ethernet. We would like to also export...
4,349
