Modicon Momentum PLC Modbus TCP Master/Slave
rudz04
May 2013
Canada
We are looking into purchasing a modicon momentum PLC that will control a slave using Modbus TCP over Ethernet. We would like to also export information from the PLC to our DCS using the same interface. The DCS will be polling the information from the PLC. Is it possible for a Modicon Momentum PLC to act as a master to control a slave while simultaneously responding requests from another master device on the same modbus tcp network?
With ModbusTCP you can do what your proposing. But Momentums are an obsolete plc, I would be looking at the Modicon M340
Thanks for the response. All the PLCs in our Mill are Modicon Momemtum, therefore we will need be use the same PLC for this addition. @GeoffC, Do you know if Schneider has this information officially documented or is it inherently part of the Modbus TCP protocol specification?
Modicon Moementum 96030 is your best choice. I don't see any problem with Momentum being master and polling a slave device.
Hey, gentlemens! I have PLC Modicon Momentum 171-CCC-96030 and ModBus registers list. I need connect to this PLC by ModBus TCP and reading...
5,551
I have a Magelis XBTGT2330 programmed with Vijeo 5.0 communicating with a Modicon TSX Momentum processor programmed with Concept v2.6. We're...
3,602
Hello i need help, I've two momentum plcs with the processor 171CCC98030-IEC and i need to put the 1º plc to read and write registers in the...
3,337
I have a 170AAO92100 card that I am interested in using as a 10 volt output. Is there setup that I have to do in order to change output or simply...
86
Hi Guys, Does Modicon M430 and Momentum Controller have In-Built Modbus SLAVE functionality or do I need to add a Modbus card to them? I'm...
3,158
