Monitor comm. between Intouch 10.0 and InSQL 9.0
pweber
Sep 2011
houston,tx
Anyone,
On how to configure Intouch to show server_fail pop-up from the SysPulse from InSQL. How to write a script for that and develop tags. Thanks
Patrick
You can monitor tags that are in the Historian from within InTouch.
First you have to set up an access name to the Historian.
NodeName =(your physical server name)
AppName = aahIOSvrSvc
TopicName = Tagname
Protocol = Suitelink
Advise All
Next you will want an InTouch tag
Create the Tag, use the above accessname, then select the item that you want to monitor. Be sure that you use the correct datatype for the tag you wish to monitor.
Can anyone tell me if Intouch 10.0 (condition scripts while true) if it can calculate seconds or minutes instead of milliseconds. Thanks
Hi all. Been surfing here since the site was recommended to me durring a Redlion sales call. I am looking for a best practice on how to have a...
3,454
We have a quad monitor setup with FT SE and we are utilizing a header screen at the top of every display. when we open a new page we abort the...
97
Our plant manger/my boss wants each line to display the takt time above the line. I am trying to research the cheapest way to do this. Our plant...
191
Hi Folks, Looking for support and ideas. We are trying to go online to monitor/fault find on an S7-300 programmed with TIA Portal V15. I can...
356
We finally replaced our Cognex Checker with an IV-3 and I'm wondering if can replace the s/w in the monitor with anything else. I haven't been...
104
