monitoring bits on other PLCs
drummin89
Jan 2012
Hazleton, Pa
49
I haven't had any experience setting up communication between two PLCs in the past so this is new to me.
I have 2 PLCs in 2 seperate pieces of equipment, 1 down stream from the other. The first PLC is a Controllogix, the second PLC (the down stream one) is a Micrologix 1100. I need the Controllogix to sound an alarm when the Micrologix goes into alarm to alert operators that the down stream equipment is not running.
All PLCs in my plant are networked together through ethernet.
I'm just not sure how to set this up.
Hello everyone! I need to connect to a DL205-1 CPU and, as far as I know, I need to use DirectSOFT 6 software for the connection. Is anyone...
67
Our punch press has a SLC500 with HELM weight module (HM-604-WM) for tonnage monitoring. The operator enters the weight range on the HMI, which is...
207
Hello, I have been trying to figure out how to connect to and monitor a DLR that is on a remote rack from my PLC. The local has a 1756-L81E and...
122
Good day, we have 15 analog inputs, we need to log the data in excel and monitor these values through web browser. We're planning to go with Delta...
130
I have several plc’s that I’d like to monitor Into our SCADA when the comms break or plc faults. These are (SLC-505 & Compact Logic PLC’s) I...
748
