Hi there, do you guys know how to detect if the flow information into a Modbus TCP/IP channel stops, i know we can see if the Ethernet port has been disconnected phisically, but i wonder if is there a way to detect if there is no information going through the channel, independently of the phisically connection.
i am reading the values from a 1420 emerson gateway using Read_Var block in Unity Pro - M340 PLC, there is a entry called Gest where i have to put a 4 Array variable of integers, i notice that the bits of one of these integers are constantly changing between 0 and 1, i also noticed that this bits stops in the last value when i lost communication with the Gateway, how could i take this information to monitoring the healty of the channel? any idea?
Thanks in advance pals!.
