Monitoring RIO ethernet status thru Studio 5000
toddp65
Aug 2014
Florence, Ky
282
Recently we've had some faults and disconnects with our 1734 aent/r module.
It shuts down all processes associated with the remote IO, obviously and the module needed to be powered down to clear the fault.
At this point I don't know what the issue is because I've never came into it before the power cycle by someone else.
At any rate, I need to create a watchdog on the controller to send out an email thru our Ignition/SCADA system to let us know someone needs to come in and reset/evaluate before we lose our systems controlled by the RIO.
I read in a search about using the GSV instruction and then pointing it to the remote module on the connections tree. I just need some more clarification on how I can do this.
Thanks!
Attached is how we do it, Hope it helps.
Thanks!
I've attached the way I did it.
Jgunnels thanks for your reply....my method isn't actually showing the ethernet connectivity but I believe it is mostly relying on led status
o_O Have not seen that before. hopefully you can get some others to chime in to see what they are doing. I think what would be the most helpful is capturing the fault code then track in down in the manual to see what the real issue is.
right...I suppose it would have to occur again to do that.
The online config page for the adapter doesn't tell me much; the unit was powered down so it doesn't seem to have retained any faults in memory
There are several methods for monitoring the I/O connection status of a remote device. I have never used the LED Status method and wouldn't recommend it.
Using GSV to read the EntryStatus (high bits 12-15) or the FaultCode are the standard method.
Or, because it's POINT I/O, you can just use the Slot Status tags that are built into the Input tag for the module. When all Slot bits = 1, the SlotStatus tag value = -1, so you can use that as a quick-and-dirty trigger for an alarm or notification without writing GSV logic.
Thanks, Ken
What about using the GSV-- Module--Fault Code---0
And then my alarm code NEQ A.Fault Code (0)________________________ (Alarm)
B. 0
edit: I see you mentioned the Fault code method
Thanks, Ken
B. 0
It may be worthwhile using both Fault and Entry. In the past I have had a module continually try to connect to a device, but it never actually faulted. In that scenario the FaultCode stayed 0.
How have you guys monitored Controlnet RIO, We have probally 6 Racks of 1756 RIO and 2 1794 RIO over controlnet. I would like to monitor it in...
2,228
Hello everyone! I need to connect to a DL205-1 CPU and, as far as I know, I need to use DirectSOFT 6 software for the connection. Is anyone...
66
Our punch press has a SLC500 with HELM weight module (HM-604-WM) for tonnage monitoring. The operator enters the weight range on the HMI, which is...
205
Hello, I have been trying to figure out how to connect to and monitor a DLR that is on a remote rack from my PLC. The local has a 1756-L81E and...
121
Good day, we have 15 analog inputs, we need to log the data in excel and monitor these values through web browser. We're planning to go with Delta...
123
