Monitoring S5 block status problem
Marshy
Apr 2007
Bath,UK
236
Had a problem today where I wanted to monitor the Block Status in Step 5. (I was using the AS511 interface). However when I enetered the block status screen I got the message: "Function idenfier in IF unknown" I was able to monitor variables in the Status Variable screen though?
We normally connect to the PLC over the "Industrial Ethernet(SINEC H1)" interface, I just didn't a patch lead in my bag at the time. When I finally got one and connected to the PLC over the IE inteface all worked OK?
Does anyone have any idea why it didn't work on the AS511 interface?
Cheers
p.s. I had searched the forumn for the problem and found 2 threads, but neither of them came to a solution?
Rich
That's a new one on me. Sounds like it was still looking at the H1 stuff in the path file.
There have always been a few quirks monitoring is S5. I remberber once using a PG635 to monitor an "AND before OR" type segment in ladder on a machine that was processing polypropylene film at 1000M/Min; the processor went straight to stop! What a mess.
Nick
Hi all. I have a Modbus ProSoft module in my setup with a capability of 30 clients (0-29), which I'm trying to monitor the Ethernet Connection...
26
Hello everyone! I need to connect to a DL205-1 CPU and, as far as I know, I need to use DirectSOFT 6 software for the connection. Is anyone...
69
Our punch press has a SLC500 with HELM weight module (HM-604-WM) for tonnage monitoring. The operator enters the weight range on the HMI, which is...
211
Hello, I have been trying to figure out how to connect to and monitor a DLR that is on a remote rack from my PLC. The local has a 1756-L81E and...
127
Good day, we have 15 analog inputs, we need to log the data in excel and monitor these values through web browser. We're planning to go with Delta...
134
