Monitoring Water Quality
Apr 2002
Just a bit northeast of nowhere
1,117
Remember last week when I asked about conductance?
My current assignment is to spec and implement a system to monitor contaminants in our parts washer. The principle things I'm concerned with are soap, oil, and to a lesser extent, particles of metal. Temp is around 200 degrees. The monitor has to be able to alarm to the washer's PLC if anything falls out of spec.
Now, I've been pursuing this thing for a couple of weeks now. I know a conductivity meter, or a Ph meter, will work for the soap. I know meters exist to measure the other two factors. But I was suprised to find that no comprehensive meter exists to measure all three.
Our vendor is being of astonishingly little help here, and various web searches turn up nothing. A search on Water Quality Monitor will get you everything from farm supply houses to the EPA, but little industrial use.
Anybody ever confront a problem like this before? If so, where did you go for a solution (pardon the pun)?
TM
Several of the devices you need can be obtained from Analytical Technologies Inc. http://www.analyticaltechnology.com
If you talk to John Becker there he can give you no BS info on his products, and probably give reliable reccommendations for sources on the stuff he can't provide.
Tell him I sent you!
Hi, We are proposing on a project where monitoring is done on a water treament plant. The treament plant has a Yokogawa recorder & the data (a...
6,994
Hello everyone! I need to connect to a DL205-1 CPU and, as far as I know, I need to use DirectSOFT 6 software for the connection. Is anyone...
68
Our punch press has a SLC500 with HELM weight module (HM-604-WM) for tonnage monitoring. The operator enters the weight range on the HMI, which is...
210
Hello, I have been trying to figure out how to connect to and monitor a DLR that is on a remote rack from my PLC. The local has a 1756-L81E and...
126
Good day, we have 15 analog inputs, we need to log the data in excel and monitor these values through web browser. We're planning to go with Delta...
133
