MONITOUCH V706c Datalog
Gonzo
Jan 2009
Rada Tilly
Hi there, excuse me if something i write doesn't make sense, i'm a bit rusty speaking or writing english, finally i hope you understand. My boss assigned me a task, it consists on basically make a datalog file with a Micrologix 1100 PLC, which can be triggered by a computer or the monitouch, so far i can do this, then (here is the part where i get lost) i have to transfer the datalog to the SRAM memory, which is in the monitouch. The problem here is that according to the manuals datalog can't be acceded by the user (by an adress i guess because there is a program to get the datalog, that AB provides) so how should i do to transfer the datalog if there is no adress of it, in the PLC. The only way i can imagine is downloading the datalog to the PC and then from the PC to the Monitouch, it would be much better if you can find another way, direct transfer from the PLC to the Monitouch. Well, there's another thing this project has to do that is once the datalog in the SRAM memory, the user has to be able to see the datalog in the screen. The monitouch soft allows spreadsheets but i don't know if can show so much information (we're talking about 3000 records or more in a screen that suports ten lines) and also i don't know how to transform the datalog data into a spreadsheet, it is saved at ASCII format just in case you don't know. Well, that's all i hope you can help me, and i hope you can understand what i have tried to express. Thanks
Hi everyone, I am having a hard time trying to get a connection between this two devices. I am already lost on what went wrong. Please help me~~~...
858
can anyone please help me with this issue i am facing.. how to upload screens from running monitouch hmi using serial to usb converter.:banghead:
1,136
Wago PLC 750-880 with Monitouch HMI. How can I tell the Wago which display is being displayed?
1,254
Has any one ever had success interfacing a Omron CJ2M 31 cpu with a Hakko Monitouch V708iSD HMI via ethernet? I am using Omron CX-One programming...
6,061
Hi! Hello, somebody can help with a cable for data transmission V6-CP for Hakko MONITOUCH V606e. With cable V6-CP with connection: RJ45-DB9 or...
2,484
