Motion Control tuning
ascot01
Jul 2007
Magnolia, TX
81
Hello,
I have a Advanced Motion Controls brushtype PWM servo amplifier (120A10D) and not being an expert I need a simplified explanation of what to expect from the motor when adjusting the 'Loop Gain' pot. The application calls for 6000 ohms and I seem to get better performance with 3000 ohms. Is there a danger of setting the resistance too high or too low? What actually changes in motor performance as the loop gain is changed from say 10k down to 2500 ohms?
Peter,
Without knowing anything about his drive, it sounds like his % gain is set via a pot. Maybe a 10k pot?
Without more info on the drive, we're grasping at straws.
-rpoet
that's right rpoet, it is a pot and it has a range of 0 to 40k ohm. I connect the ohmmeter across the pot terminal and signal ground and the pot varies the resistance while watching the ohms reading on the meter.
FYI, Frequent PLCS contributor Peter Nachtwey had an article published in the current issue of the engineering magazine Design News, see...
3,574
Hello everybody, I'm currently working on a project where I need to implement an IoT platform based on Microsoft Azure Cloud. Communication is...
72
I have always controlled servos in Rockwell motion using position loop. I have an application where one process will push against a servo...
293
How do I adjust motion control parameters using Logix Designer? Such as: motion axis stop I will make an adjustment like changing the...
328
Hey guys, On my system, i got prop valve controling cylinder on the left and right to adjust the center of a lumber before it get in a woodmill...
952
