Motor Condition Monitoring
Have had a couple of requests from customers for condition monitoring systems. They usually drop the idea when they hear the price :)
Instead of a permanently installed monitoring system, which will be very expensive for the sensors, the cabling and the monitoring hardware, as a cheaper alternative have a set of vibration sensor + monitor that can be installed on a for the purpose prepared measuring point (i.e. a predrilled and threaded hole in the part that has to be monitored). Then have a guy go around monthly and take manual readings.
Combine with thermographic images and you have a reasonably good preventive maintenance regime.
Our motor failures are few and far between but every time we do have a failure, it turns into this big "How can we prevent anything like this form ever happening again!!!?" situation and the then monitoring is the new panic, till the next panic comes along.. We seem to do this with many different downtime events.
Ahhh, the good old engineering/management disconnect... "what can we do to avoid this happen that doesn't involve any investment whatsoever?"
I've got this 3-phase 575V motor that we're controlling with a VFD (Variable Frequency Drive), which has been quite the learning curve in itself...
258
Hello, It is mandatory to use VFD IF i use IE5 electrical motor? What happens If connect it directly as delta without VFD? Please look at motor...
147
Here's what happened, Operator turned on the disconnect for an auger while it was still running to cut power. Auger DID in fact turn off, but the...
347
Hello all, In my facility we have multiple 3HP 460V motors that are being controlled by VFDs which drive conveyor belts. The drives are randomly...
216
Hi everyone, This is my first time posting, so please forgive any omissions or mistakes. I am attempting to control the velocity of a stepper...
18
1,036
