basharath Member B Join Date Mar 2010 Location hyderabad Posts 103 Nov 3, 2010 #1 we have motor run feed back and trip fedback..from where do we take this feedback from the field. thanks.
IJK Member I Join Date Sep 2010 Location pune Posts 67 Nov 3, 2010 #2 The Simplest way is use contactor contacts for run feed back in the panel it self. or u can use an MPCB which will provide u trip feedback.
Tom Jenkins Lifetime Supporting Member Join Date Apr 2002 Location Milwaukee, WI Posts 6,302 Nov 3, 2010 #3 Most starters have auxiliary contacts on the starter contact and the overload for status indication. I usually use NO for Run and NC for overload. For some less expensive IEC starters you will have to use adder blocks for the auxiliary contacts.
Jeff23spl Member J Join Date Jan 2010 Location Canada Posts 860 Nov 3, 2010 #4 our standard is to have the overload NC connected to release the contactor coil when tripped and the NO signal the plc of overload trip
