ElectricalHammer
Not totally PLC related, but I figured this would be a good place to ask:
I have an application where 7 small parts are being gripped and then held together to get welded. The final assembly is like a 3 footed chair stand, but only about 150mm in diameter: a central cone/cylinder, 3 legs, 3 feet.
Anyways, I have a coworker suggesting we use stepper motors because he thinks they will vibrate (jitter/dither) less when holding the parts against each other. Fair enough, steppers are cheaper as well. I was thinking with servos we would advance the parts to hold them together and then turn them off and rely on the motor brakes.
My issue is that steppers don't really have the longevity of a servo, and unless an encoder is added, they don't really have any feedback. Okay, we can add an encoder to a stepper, but one part of the poka yoke I was considering is after all 7 parts are loaded, I wanted to do a pre-check by advancing all the parts against each other until they hit a given torque (force feedback) to check that the parts are loaded properly. To the best of my knowledge, there is no force-feedback for stepper motors, is there?
